Boiler feed pump by Microcosm
Message par derekwarner_decoy le Dim 21 Avr 2013 - 1:31
KBIO.......I try again ....... 8)..........both of these links open for me from my message posting here .... :comprend pas Derek
It is a funny relationship being 6 mm bore x 5 mm hub.....but I have the small 12 Vdc geared motor @ 70 RPM & very low current also has a 4.0 mm diameter output shaft so will match the M4 pump eccentric  roi
I am sure that this combination will not make the  🔫  :hurle  noise of the Regner units........
