New project
FORUM MODELISME NAVAL RADIOCOMMANDE :: MODELISME NAVAL :: MODELISME BATEAUX A VAPEUR :: "STEAM FELLOWS from overseas"
New project
This is the model I am working on at the moment power will be via the MB22 Paddleducks engine built from the site of the same name.
steamup- Age : 62
Re: New project
Fantastic project
I love the line of the boat
Press to see the progress
Sincerelys
Marc
Sincerelys
Marc
marcovi- Age : 62
Re: New project
It sounds fine to me.
I love your launch! Very uncommon by the shape and the rudder!
Cheers.
ps: do you still have problems to insert photos??
Cheers.
Re: New project
un chinois qui chaufferai au charbon de préférence !!
apparemment pas de confrères outre manche pour l'instant.
Re: New project
Lovely!
It looks like it wont be long before we see everything running on the pond!
Cheers.
Lovely!
Cheers.
Re: New project
Hello !
I like the rear of the cant with are rudder type "Admiral KITCHEN"
A beautiful set steam
Re: New project
Progressing on this nice setting.
But the glass of wine has disapeared. Must be empty!
Cheers!
Cheers!
Re: New project
Nice setting, working good!
The video does not allow to see it all, but, is the height of the priming , low enough??
Cheers?
Cheers?
Re: New project
The mechanism will be in the seating with the water tank slightly higher in the bow.
This should provide for gravity feed to prime the pump.
steamup- Age : 62
Re: New project
:hello:Hello!
The result is OK!
It would be interesting to know which one has the best performances.
Cheers.
The result is OK!
Cheers.
Re: New project
Hello Steamup.
Mint condition!
You see when you sail if you need some weight. But as long as the propeller stays under water, you better keep light.
Waiting on next pics.
Cheers.
Mint condition!
Cheers.
Re: New project
Hello Steamup.
I thought that you run this machine with steam already??
Fixing the leak will obviously increase the output. But it runs fine so far.
What is the next step?
I definitvly love your launch.
Cheers!
Cheers!
Re: New project
I tried it on steam made alterations then lost the timing .
After much head scratching I manged to sort the problem out. I think the engine will need some running in ,it is already showing improved running after a couple of steam ups.
steamup- Age : 62
Re: New project
Hello;
Bah, leaks these art of mechanics, and wandering steam lubricates the mechanical
Kind regards
Kind regards
