Réparation du Stuart de ROY.
FORUM MODELISME NAVAL RADIOCOMMANDE :: MODELISME NAVAL :: MODELISME BATEAUX A VAPEUR :: "STEAM FELLOWS from overseas"
Roy nous fait part des problèmes de sa machine et de la façon dont il les a résolu.
Je vous laisse apprécier le travail.
Cheers Roy.
the isis boat engine developed a timing fault : all the steam was poring out of the sump: !!!
so I took off the base plate and adjusted the bevel gears, so the lead piston ( right hand side ) was now set at tdc )
and the pinion pin rotated to the new correct position,
the slider plate replaced making sure the pinion pin remains at the correct position.
all the screws put back,
engine test prove the engine run much faster, and smoother ;
now back on hull restoration
Best regards Roy
Cheers Roy.
Best regards Roy
» Réparation navale
» Réparation de l'antenne d'un récepteur
» etancheite coque
» Réparation de petites pièces en carbone
» Réparation d'une machine semi Flash Steam Anglaise vintage
» etancheite coque
