Joints thorique EPDM
FORUM MODELISME NAVAL RADIOCOMMANDE :: MODELISME NAVAL :: MODELISME BATEAUX A VAPEUR :: LA SECURITE DANS LA VAPEUR
Ayant quelques difficultés a trouver des joints théorique de section 6,2x2,4 pour des petites vannes gaz je me pose la questions si les joints en EPDM puissent convenir pour le gaz voire vapeur également .
@+ Bruno
@+ Bruno
Le Yéti du Nord ...
Opale62- Age : 67
Mootness EPDM gaskets
Dear GAZOU........I read this message below from your French WEB site, however I can never post a response.....
I would like to answer @+Bruno [Message by Opale62 on Sun 29 Mar 2015 - 19] as follows
O-ring sizing [theoretical section] 6, 2 x 2, 4 is non standard
A Standard BS2-108 o-ring is 6.02 x 2.62
I have 48 years as hydraulic engineer for Marine, Department of Defence [Navy] and Steel industry before retirement
BS2-108 is slightly smaller in inner diameter and marginally larger in cross section...so will stretch for the larger diameter requirement and thus also the stretch reduces the cross section
BS2-108 are also readily available in elastomer EPDM [80 Shore A hardness]
EPDM elastomer is compatible with steam to 150 degrees C
EPDM elastomer is also compatible with butane/propane gas to 100 degrees C
Could you please forward my message on to @+Bruno
My landline e-mail is au if needed
Derek : if needed
Derek Warner
Honorary Secretary
Illawarra Live Steamers
Australia
www.ils.org.au
_____________________________________________________________________________________
Message by Opale62 on Sun 29 Mar 2015 - 19:15
Having some difficulties to find seals theoretical section 6, 2 x 2, 4 for small gas valves I ask myself the questions if the seals in EPDM can be suitable for gas or steam also.
Thank you
@+ Bruno
Derek : if needed
Derek Warner
Honorary Secretary
Australia
www.ils.org.au
Thank you
@+ Bruno
derekwarner_decoy- Age : 74
Re: Joints thorique EPDM
Hello Derek!
Thanks a lot for your valuable information.
I guess that Bruno got the message OK, by now!
I erased your mail adress to make sure no frog will bother you on the good side of the Big Blue!
Always a pleasure to know that you come along with us.
Best regards!
Best regards!
» Joints OR
» joints & O'ring
» Joints divers ..
» fabrication de joints plats métalliques
» Sécurité et choix des joints en vapeur.
» joints & O'ring
» Joints divers ..
